in BSP Cloning Wizard doesn't appear my customk60n512 BSP
1,060 次查看
Angelillo
I have used "BSP Cloning Wizard" (tool included by MQX 4.0) to create a customk60n512 BSP from twrk60n512 Board Base. The result has been successful. Now, I need to create a new_customk60n512 BSP from my customk60n512 BSP created before, but my customk60n512 BSP doesn't appear as Board Base in the BSP Cloning Wizard menu. Does anyone have any ideas?
Thanks in advance,
Ángel G.
标记 (2)
619 次查看
c0170
Senior Contributor III
Hello angel gutierrez,
cloning wizard does not currently support cloning already cloned bsp.
MartinK
619 次查看
Angelillo
OK. Thank you for your support MartinK,
Ángel G.
620 次查看
c0170
MartinK
