imx8mm gpio interrupt could not bind from cpu0 to other
1,964 次查看
sofia_0571
too many interrupts(gpio5_3 as interrupt source) to respond. I want to bind from cpu0 to other cpus.
I have tested it by irq_set_affinity, but it didn’t work.
last found chip->irq_set_affinity is null.now how to do it?
thanks.
标记 (1)
1,952 次查看
Hi David
one can try to run application which uses that interrupt on specific core using examples with taskset :
in sect.6.9.4 AN12118  i.MX 8M Quad Power Consumption Measurement
or  https://community.toradex.com/t/can-packets-dropped-if-high-bus-load-on-apalis-imx8-boot2qt-image-an...
