Hi Community members,
I need to work on an IP camera which is connected to the i.MX8MP board. I need to capture live stream from the camera and send it to another public address.
Can anyone give suggestion how to achieve this?
Thanks in advance,
Deepika
Solved! Go to Solution.
Hello,You may refer to the following document, section 10.2 Camera streaming
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX-8-GStreamer-User-Guide/ta-p/1098942Best regards,Aldo.
Hi All,
Any suggestions would be helpful.
