in the K60F120,there has a SRAM,now the MQX has add the configuration in _bsp_flexbus_setup(0) and _bsp_flexbus_mram_setup().but in the application program,how can i use the SRAM? for example,i want to define a big data array in the SRAM .
已解决! 转到解答。
Hi qin chenghu,
Please check the below threads and let me know if this helps,
Best Place to add external SRAM in MQX
Anybody added external SRAM to Kinetis K60 while using MQX.
Sol
Hi qin chenghu,
Sol
