how to manually install MQX 3.8 extensions for CodeWarrior PA professional edition V8.8?
668 次查看
rhelfan
Hi, I'm using CodeWarrior PA professional edition V8.8 for developing MPC8309 application.  After install MQX 3.8, I cannot install extensions (under tool subdirectory) manually into CodeWarrior directory, Could you give me some advice?
Thank you.
554 次查看
soledad
Hello Ryan
There exists a patch for MQX. It is on the DVD that comes with the board: TWR_MPC8309_FSL_MQX_BSP.zip
It is created by Embedded Access, so for any questions about mqx 3.8.1 or 4.0 or support question related to it should be sent to support@embedded-access.com, as stated in the FSL_MQX_MPC830X_release_notes.pdf in the package.
Sol
