I am using MQX3.8 and am trying to close (fclose) an I2C interface then reopen it (fopen)
The following code is used to first open the connection
file_iic0 = fopen("ii2c1fb:", NULL);
The following code is used to close the connection
fclose(file_iic0) ;
The fopen succeeds and my program can communicate with an I2C device
The fclose succeeds
Then I try to "reopen" the device using
The fopen never returns.
Is there some problem closing an I2C connection then reopening it?
Mike
Found solution.
In the routine _info_struct_init(), file i2c_int_k_fb.c, three light weight events are created. They have to be destroyed in _ki2c_int_fb_deinit().
Hi Mike:
Thank you for sharing your experience.
I have tested this demo in the lastest MQX version 4.2. not found this issue.
Have a nice day!
