example using IO_IOCTL_SERIAL_GET_STATS
1,151件の閲覧回数
leepenn
Does anyone have an example on using IO_IOCTL_SERIAL_GET_STATS to see the io_info_ptr->RX_CHARS? I am having trouble determining how to properly turn the params pointer into the io_info_ptr.
Lee
798件の閲覧回数
soledad
Hello Lee Penn,
IO_IOCTL_SERIAL_GET_STATS is used to get the statistics information of the serial port, e.g. Rx parity error, overrun, etc.    If you want to check whether there is character received, _io_fstatus() could be used like:        bCharRecved = _io_fstatus(uart3_file);
You may use that code as reference. I hope it helps!!!
Sol
/* Task IDs */
#define NILL_TASK 5
extern void nill_task(uint_32);
KUART_INFO_STRUCT stats;
// serial port settings
uint_32 baud = 9600, *baud_ptr = &baud;
uint_32 databits = 9, *databits_ptr = &databits;
uint_32 stopbits = 1, *stopbits_ptr = &stopbits;
//uint_8 parity = IO_SERIAL_PARITY_NONE, *parity_ptr = &parity;
uint_32 parity = IO_SERIAL_PARITY_EVEN, *parity_ptr = &parity;
//uint_8 parity = IO_SERIAL_PARITY_ODD, *parity_ptr = &parity;
//uint_8 parity = IO_SERIAL_PARITY_MARK, *parity_ptr = &parity;
const unsigned char serial_options = (IO_SERIAL_RAW_IO);
const char sendstring[] = "ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789abcdefghijklmnopqrstuvwxyz", *sendstring_ptr = &sendstring[0];
char recvstring[20];
const TASK_TEMPLATE_STRUCT MQX_template_list[] =
  /* Task Index, Function, Stack, Priority, Name, Attributes, Param, Time Slice */
  { NILL_TASK, nill_task, 4000, 8, "nill", MQX_AUTO_START_TASK, 0, 0 },
  { 0 }
/*TASK*-----------------------------------------------------
* Task Name : nill_task
* Comments :
* This task does nothing
*END*-----------------------------------------------------*/
void nill_task
  uint_32 initial_data
  MQX_FILE_PTR serial_fd;
  uint_32 flags = IO_SERIAL_NON_BLOCKING;
  serial_fd = fopen("ttyd:", (char const*) serial_options);
  ioctl(serial_fd, IO_IOCTL_SERIAL_SET_BAUD, baud_ptr);
  ioctl(serial_fd, IO_IOCTL_SERIAL_SET_FLAGS,&flags );
  write(serial_fd, (void *) sendstring_ptr, 62);
  ioctl( serial_fd , IO_IOCTL_SERIAL_WAIT_FOR_TC, NULL );
  fflush(serial_fd);
  ioctl( serial_fd, IO_IOCTL_SERIAL_GET_STATS, (pointer)&stats);
  ioctl(serial_fd, IO_IOCTL_SERIAL_GET_FLAGS,&flags );
  while(1)
  read(serial_fd, recvstring, 20);
  _io_fclose(serial_fd);
  _mqx_exit(0);
2 返答(返信)
798件の閲覧回数
DavidS
Hi Lee,
I have implemented it in the code at the following post differently than soledad (her approach is nicer):
Receiving characters from a UART under MQX
I was looking at the  RX_OVERRUNS field specifically buy with the call below you get all the flags to review.
  uint32_t param[15];          //DES has extra room to buffer
      if(lengthRead) {
        _io_ioctl(stdout, IO_IOCTL_SERIAL_GET_STATS, &param);          //DES get UART statisics
        if(param[7]) {          //DES check RX_OVERRUNS
          _io_puts("\nRX_OVERRUNS Error...\n");
          fflush(stdout);
          _io_ioctl(stdout, IO_IOCTL_SERIAL_CLEAR_STATS, &param);          //DES clear UART statisics
Look in serl_kuart.h for definitions of the Stats.
typedef struct kuart_info_struct
   /* The current init values for this port */
   KUART_INIT_STRUCT          INIT;
   /* The sci device register */
   UART_MemMapPtr             SCI_PTR;
   /* The previous interrupt handler and data */
   void       (_CODE_PTR_ OLD_ISR)(void *);
   void       (_CODE_PTR_ OLD_ISR_EXCEPTION_HANDLER)(uint32_t, uint32_t, void *,
               void *);
   void                             *OLD_ISR_DATA;
   /* Various flags */
   uint32_t                           FLAGS;
   /* Statistical information */
   uint32_t                           INTERRUPTS;
   uint32_t                           RX_CHARS;
   uint32_t                           TX_CHARS;
   uint32_t                           RX_BREAKS;
   uint32_t                           RX_PARITY_ERRORS;
   uint32_t                           RX_FRAMING_ERRORS;
   uint32_t                           RX_OVERRUNS;
   uint32_t                           RX_DROPPED_INPUT;
   uint32_t                           RX_NOISE_ERRORS;
Look in serl_pol_kuart.c for the order in which the param array gets filled as it is slightly different than the definition order.
      case IO_IOCTL_SERIAL_GET_STATS:
         *param_ptr++ = io_info_ptr->INTERRUPTS;
         *param_ptr++ = io_info_ptr->RX_CHARS;
         *param_ptr++ = io_info_ptr->TX_CHARS;
         *param_ptr++ = io_info_ptr->RX_BREAKS;
         *param_ptr++ = io_info_ptr->RX_PARITY_ERRORS;
         *param_ptr++ = io_info_ptr->RX_FRAMING_ERRORS;
         *param_ptr++ = io_info_ptr->RX_OVERRUNS;
         *param_ptr++ = io_info_ptr->RX_DROPPED_INPUT;
         *param_ptr++ = io_info_ptr->RX_NOISE_ERRORS;
         break;
David
799件の閲覧回数
soledad
Hello Lee Penn,
Sol
/* Task IDs */
#define NILL_TASK 5
  { 0 }
* Comments :
void nill_task
  fflush(serial_fd);
  while(1)
  _mqx_exit(0);
