ethernet working on mqx 4.2
1,031件の閲覧回数
Abil
hi  all,
am using FRDM k64 with MQX 4.2 and code warrior 10.6...i have build RTCS library and tried to build example code..ya its working perfectly...but if i tries to make it run from my tasks or functions its working only from one side..ie. from TCP to serial....can anyone suggest how to do it?
3 返答(返信)
931件の閲覧回数
danielchen
Hi shweta:
Could you please attach your code ,so we can reproduce your issue?
931件の閲覧回数
Abil
i have attached my code here....am calling this functions rx_task and
tx_task() from task in main
On Mon, Feb 15, 2016 at 7:56 AM, danielchen@fsl <
931件の閲覧回数
danielchen
Hi shweta:
Since your functions can only work from TCP to serial, I suggest you check the tx_task.  there is only one send function in this task, whether the input parameter is valid?
