can't open 3 channels in one adc module
已解决
跳至解决方案
962 次查看
duwufeng
      I  use the mqx3.8.1 and mk60,I want to use 3 channels in adc0 module,but the first and second second channel can be opened,the third channel will open failed.
      my adc channel initial structures are right,and if I change the channels open sequence,always the same result,only the third channel can't work.how can I handle this???
thanks !!!
标记 (3)
1 解答
822 次查看
duwufeng
the problem has been solved, because of the mk60's hardware configuration.
在原帖中查看解决方案
1 回复
823 次查看
duwufeng
