Using MQX 4.1 on a Vybrid. This seems simple, but I can't get the system to open a file unless I search through the directory using FIND_FIRST_FILE and then FIND_NEXT_FILE. Then, I can use the name that it finds and use fopen in the usual way. The SD card interface is proven in the design so I don't believe it is a hardware problem.
Mark
