What is the Time delay function in MQX? Using board Kwikstik K40
2,367 次查看
yasararafath
Hi all,
     I have just started working on MQX RTOS. In that i am not able to understand it.
     I need sample code and how to run the MQX application in KwikStik K40.
     And also i need a timer and delay function in that timer. If anybody can please...
标记 (5)
1,161 次查看
c0170
Senior Contributor III
What have you done so far?
Please review the code which is provided within MQX installation. There are examples for the Kwikstik. Firstly, build BSP and PSP for the Kwikstick board then run timer example.
More information available Chapter 3.8 TIMING in MQX User Guide.
c0170
1,162 次查看
c0170
c0170
1,161 次查看
yasararafath
Thank You, Kojtal.
