Unable to get Wi-Fi working properly on Android Oreo on i.Mx6 SabreSD
9,952件の閲覧回数
susangracerapak
Hi ,
I am working on Android Oreo with Custom Wi-Fi driver on i.Mx6 SabreSD board.  I am unable to get Wi-Fi Working properly, after getting Wi-Fi scan results on GUI, Wi-Fi is going off.I am observering some issue with P2P. I have disabled P2P in android.config file but still I am seeing P2P enabled prints.
How to disable P2P on android OREO?
The logs are,
WifiStateMachine: Before StartMonitoring***************** mInterfaceNmae is wlan0
wpa_supplicant: wpa_supplicant v2.7-devel-8.0.0
wpa_supplicant: random: Added entropy from /data/misc/wifi/entropy.bin (own_pool_ready=2)
wpa_supplicant: random: Trying to read entropy from /dev/random
wpa_supplicant: Get randomness: len=20 entropy=1
wpa_supplicant: random: Updated entropy file /data/misc/wifi/entropy.bin (own_pool_ready=2)
wpa_supplicant: Global control interface '@android:wpa_wlan0'
wpa_supplicant: Using Android control socket 'wpa_wlan0'
wpa_supplicant: Initing hidl control
wpa_supplicant: Processing hidl events on FD 5
wpa_supplicant: Successfully initialized wpa_supplicant
wpa_supplicant: ****** in wpa_supplicant_init_iface******
wpa_supplicant: Initializing interface 'wlan0' conf '/vendor/etc/wifi/wpa_supplicant.conf' driver 'nl80211' ctrl_interface 'N/A' bridge 'N/A'
wpa_supplicant: Configuration file '/vendor/etc/wifi/wpa_supplicant.conf' -> '/vendor/etc/wifi/wpa_supplicant.conf'
wpa_supplicant: Reading configuration file '/vendor/etc/wifi/wpa_supplicant.conf'
SupplicantP2pIfaceHal: IServiceNotification.onRegistration for: android.hardware.wifi.supplicant@1.0::ISupplicant, default preexisting=false
system_server: Looking for service android.hardware.wifi.supplicant@1.0::ISupplicant/default
wpa_supplicant: ctrl_interface='wlan0'
wpa_supplicant: update_config=1
wpa_supplicant: eapol_version=1
wpa_supplicant: ap_scan=1
wpa_supplicant: fast_reauth=1
wpa_supplicant: pmf=1
wpa_supplicant: uuid=12345678-9abc-def0-1234-56789abcdef0
wpa_supplicant: device_name='RS9113_n-Link'
wpa_supplicant: manufacturer='Redpine Signals INC'
wpa_supplicant: model_name='OneBox-Mobile'
wpa_supplicant: model_number='9113'
wpa_supplicant: serial_number='03'
wpa_supplicant: os_version=01020300
wpa_supplicant: config_methods='display push_button keypad'
wpa_supplicant: persistent_reconnect=1
wpa_supplicant: p2p_disabled=1
wpa_supplicant: Line: 24 - start of a new network block
wpa_supplicant: ssid - hexdump(len=12): 52 45 44 50 49 4e 45 5f 4f 50 45 4e
wpa_supplicant: key_mgmt: 0x4
wpa_supplicant: priority=2 (0x2)
wpa_supplicant: Line: 31 - start of a new network block
wpa_supplicant: ssid - hexdump(len=15): 52 45 44 50 49 4e 45 5f 41 50 5f 43 43 4d 50
wpa_supplicant: key_mgmt: 0x2
wpa_supplicant: PSK (ASCII passphrase) - hexdump(len=8): [REMOVED]
wpa_supplicant: priority=1 (0x1)
system_server: Starting thread pool.
wpa_supplicant: PSK (from passphrase) - hexdump(len=32): [REMOVED]
wpa_supplicant: Priority group 2
wpa_supplicant:    id=0 ssid='REDPINE_OPEN'
wpa_supplicant: Priority group 1
wpa_supplicant:    id=1 ssid='REDPINE_AP_CCMP'
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:1
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:5
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:2
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:4
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:10
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:8
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:9
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:6
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:13
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:11
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:12
wpa_supplicant: nl80211: Driver-advertised extended capabilities (default) - hexdump(len=8): 00 00 00 00 00 00 00 40
wpa_supplicant: nl80211: Driver-advertised extended capabilities mask (default) - hexdump(len=8): 00 00 00 00 00 00 00 40
wpa_supplicant: nl80211: use P2P_DEVICE support
wpa_supplicant: nl80211: interface wlan0 in phy phy5
wpa_supplicant: nl80211: Set mode ifindex 9 iftype 2 (STATION)
wpa_supplicant: nl80211: Subscribe to mgmt frames with non-AP handle 0xac92d7a8
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=0104
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=040a
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=040b
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=040c
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=040d
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=090a
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=090b
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=090c
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=090d
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=0409506f9a09
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=7f506f9a09
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=0801
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=06
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=0a07
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=0a11
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=0a1a
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=1101
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=1102
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=0505
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=0500
wpa_supplicant: rfkill: Cannot open RFKILL control device
wpa_supplicant: nl80211: RFKILL status not available
wpa_supplicant: netlink: Operstate: ifindex=9 linkmode=1 (userspace-control), operstate=5 (IF_OPER_DORMANT)
wpa_supplicant: Add interface wlan0 to a new radio phy5
wpa_supplicant: nl80211: Regulatory information - country=00
wpa_supplicant: nl80211: 2402-2472 @ 40 MHz 20 mBm
wpa_supplicant: nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR)
wpa_supplicant: nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
wpa_supplicant: nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR)
wpa_supplicant: nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR)
wpa_supplicant: nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR)
wpa_supplicant: nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR)
wpa_supplicant: nl80211: 57240-63720 @ 2160 MHz 0 mBm
wpa_supplicant: nl80211: Added 802.11b mode based on 802.11g information
wpa_supplicant: wlan0: Own MAC address: 00:23:a7:90:3c:a0
wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=9 (wlan0) alg=0 addr=0x0 key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=9 (wlan0) alg=0 addr=0x0 key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=9 (wlan0) alg=0 addr=0x0 key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=9 (wlan0) alg=0 addr=0x0 key_idx=3 set_tx=0 seq_len=0 key_len=0
wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=9 (wlan0) alg=0 addr=0x0 key_idx=4 set_tx=0 seq_len=0 key_len=0
wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=9 (wlan0) alg=0 addr=0x0 key_idx=5 set_tx=0 seq_len=0 key_len=0
wpa_supplicant: wlan0: RSN: flushing PMKID list in the driver
wpa_supplicant: nl80211: Flush PMKIDs
wpa_supplicant: TDLS: TDLS operation not supported by driver
wpa_supplicant: TDLS: Driver uses internal link setup
wpa_supplicant: TDLS: Driver does not support TDLS channel switching
wpa_supplicant: WPS: Converting display to virtual_display for WPS 2.0 compliance
wpa_supplicant: WPS: Converting push_button to virtual_push_button for WPS 2.0 compliance
wpa_supplicant: wlan0: WPS: UUID based on configuration: 12345678-9abc-def0-1234-56789abcdef0
wpa_supplicant: EAPOL: SUPP_PAE entering state DISCONNECTED
wpa_supplicant: EAPOL: Supplicant port status: Unauthorized
wpa_supplicant: nl80211: Skip set_supp_port(unauthorized) while not associated
wpa_supplicant: EAPOL: KEY_RX entering state NO_KEY_RECEIVE
wpa_supplicant: EAPOL: SUPP_BE entering state INITIALIZE
wpa_supplicant: EAP: EAP entering state DISABLED
wpa_supplicant: global ctrl interface @android:wpa_wlan0 matches ctrl interface wlan0 - do not open per-interface ctrl interface
wpa_supplicant: Registering interface to hidl control: wlan0
wpa_supplicant: Registering network to hidl control: 0
wpa_supplicant: Registering network to hidl control: 1
wpa_supplicant: wlan0: Added interface wlan0
wpa_supplicant: wlan0: State: DISCONNECTED -> DISCONNECTED
wpa_supplicant: nl80211: Set wlan0 operstate 0->0 (DORMANT)
wpa_supplicant: netlink: Operstate: ifindex=9 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
wpa_supplicant: random: Got 20/20 bytes from /dev/random
wpa_supplicant: Get randomness: len=20 entropy=0
wpa_supplicant: RTM_NEWLINK: ifi_index=9 ifname=wlan0 operstate=2 linkmode=1 ifi_family=0 ifi_flags=0x3 ([UP])
SupplicantStaIfaceHal: +++++++ in initSupplicantStaIface
SupplicantStaIfaceHal: +++++++ in initSupplicantStaIface try
SupplicantStaIfaceHal: +++++++ in initSupplicantStaIface before  addALL
SupplicantStaIfaceHal: +++++++ in Mutable 2
SupplicantP2pIfaceHal: entering getInterface()
SupplicantStaIfaceHal: +++++++ in initSupplicantStaIface try1
SupplicantP2pIfaceHal: initSupplicantP2pIface got null iface
SupplicantP2pIfaceHal: initalizing ISupplicantIfaces failed.
wpa_supplicant: *****IN wpa_supplicant_get_iface***
wpa_supplicant: IN wpa_supplicant_get_iface ifname is wlan0
SupplicantStaIfaceHal: +++++++ iface is ISupplicantIface android.hardware.wifi.supplicant@1.0::ISupplicantStaIface@Proxy
SupplicantStaIfaceHal: Failed to get ISupplicantIface android.hardware.wifi.supplicant@1.0::ISupplicantStaIface@Proxy
SupplicantStaIfaceHal: Failed to get supplicantIface.value android.hardware.wifi.supplicant@1.0::ISupplicantStaIface@Proxy
SupplicantStaIfaceHal: +++++++ ifaceName.value wlan0
SupplicantStaIfaceHal: Completed initialization of ISupplicant interfaces.
WifiMonitor: +++++++ in startMonitoring iface is wlan0
WifiMonitor: +++++++ after startMonitoring ifwlan0
WifiMonitor: +++++++ inbroadcastSupplicantConnectionEvent wlan0
SupplicantStaIfaceHal: +++++++++++++++++++++In getMacAddress
WifiConfigManager: Legacy store files not found. No migration needed!
WifiStateMachine: Setting OUI to DA-A1-19
WifiHAL : Sending mac address OUI
WifiHAL : failed to set scanning mac OUI; result = -95
WifiVendorHal: setScanningMacOui(l.1452) failed {.code = ERROR_NOT_AVAILABLE, .description = }
WifiHAL : Failed to register debug response; result = -95
android.hardware.wifi@1.0-service: Failed to get driver version: SUCCESS
WifiVendorHal: requestChipDebugInfo(l.1734) failed {.code = ERROR_NOT_AVAILABLE, .description = failed to get driver version}
WifiVendorHal: Driver: null Firmware: null
WifiVendorHal: getRingBufferStatus(l.1811) failed {.code = ERROR_NOT_AVAILABLE, .description = }
WifiDiags: no ring buffers found
WifiHAL : Start get packet fate command
WifiHAL : createRequest Monitor packet fate request
WifiHAL : Failed to register get pkt fate response; result = -95
WifiVendorHal: startPktFateMonitoring(l.1897) failed {.code = ERROR_NOT_AVAILABLE, .description = }
WifiDiags: Failed to start packet fate monitoring
wpa_supplicant: wpa_driver_nl80211_driver_cmd: failed to issue private command: BTCOEXSCAN-STOP
SupplicantStaIfaceHal: ISupplicantStaIface.setBtCoexistenceScanModeEnabled failed: FAILURE_UNKNOWN,
wpa_supplicant: wpa_driver_nl80211_driver_cmd: failed to issue private command: RXFILTER-STOP
SupplicantStaIfaceHal: ISupplicantStaIface.stopRxFilter failed: FAILURE_UNKNOWN,
wpa_supplicant: wpa_driver_nl80211_driver_cmd: failed to issue private command: SETSUSPENDMODE 0
SupplicantStaIfaceHal: ISupplicantStaIface.setSuspendModeEnabled failed: FAILURE_UNKNOWN,
WifiNative-wlan0: +++++++++++++++++++++In setPowersave in wifiNative.java
SupplicantStaIfaceHal: +++++++++++++++++++++In setPowerSave
SupplicantStaIfaceHal: In try+++++++++++++++++++++In setPowerSave
audio_hw_primary: do_out_standby... -1362246336
hw-IPCThreadState: binder thread pool (1 threads) starved for 2045 ms
DHCP    : +++++++ in ifc_init
CommandListener: argv[0]=interface argv[1] = getcfg argv[2]=wlan0
DHCP    : +++++++ in ifc_get_info
DHCP    : +++++++ in ifc_get_hwaddr
SupplicantStaIfaceHal: +++++++++++++++++++++In enableAutoReconnect
RttService: SCAN_AVAILABLE : 3
WifiScanningService: wifi driver loaded with scan capabilities: max buckets=16
RttService: DefaultState got{ when=0 what=160512 target=com.android.internal.util.StateMachine$SmHandler }
CommandListener: Setting iface cfg
wificond: New interface event callback registered
DHCP    : +++++++ in inint_sockaddr
RttService: EnabledState got{ when=0 what=160516 obj=android.net.wifi.IClientInterface$Stub$Proxy@326922e target=com.android.internal.util.StateMachin}
WifiP2pService: Unable to change interface settings: java.lang.IllegalStateException: command '69 interface setcfg p2p0 0.0.0.0 0 broadcast up' failed'
WifiP2pService: Callling startMonitoring in P2P
WifiP2pMonitor: startMonitoring(p2p0)
WifiVendorHal: getSupportedFeatureSet(l.898) failed {.code = ERROR_NOT_AVAILABLE, .description = }
WifiVendorHal: getSupportedFeatureSet(l.904) failed {.code = ERROR_NOT_AVAILABLE, .description = }
HalDeviceManager: +++++++ in getAllChipInfo
WifiManager: In get Scanresults
android.hardware.wifi@1.0-service: +++++++ in getAvailable ModesInternal
android.hardware.wifi@1.0-service: getAvailable ModesInternal p2p
WifiManager: In getConfiguredNetworks
android.hardware.wifi@1.0-service: +++++++ in getStaIfaceNames
HalDeviceManager: +++++++ before WifiIfaceInfo
HalDeviceManager: +++++++ calling getStaIface
HalDeviceManager: +++++++ statusOk
HalDeviceManager: +++++++ ifaceName = wlan0
HalDeviceManager: +++++++ iface = android.hardware.wifi@1.0::IWifiStaIface@Proxy
HalDeviceManager: +++++++ ifaceInfo.iface = android.hardware.wifi@1.0::IWifiStaIface@Proxy
HalDeviceManager: +++++++ ifaceInfo.name = wlan0
android.hardware.wifi@1.0-service: +++++++ in getP2pIfaceNames
android.hardware.wifi@1.0-service: +++++++ in getP2pIfaceNamesInternal
HalDeviceManager: +++++++ before P2p
WifiConnectivityHelper: Firmware supported feature set: 19
WifiConnectivityHelper: Firmware roaming is not supported
WifiStateMachine: disconnectedstate enter
WificondScannerImpl: +++++++ in startsingle scan
WificondControl: +++++SUSAN start scan
wificond: In wificond Scan
wificond: In wificond i value is0
wificond: In wificond ssids.size  is1
wificond: In wificond SSID[i]0
wificond: In wificond before trigger_scan
wificond: In netlink SendMessageAndGetAckOrError
BatteryStatsService: no controller energy info supplied
WifiManager: return list
WifiSettings: onAccessPointsChanged (WifiTracker) callback initiated
WifiP2pMonitor: setMonitoring(p2p0)
WifiP2pMonitor: startMonitoring(p2p0) failed!
WifiP2pService: P2p socket connection failed
Here I am seeing Wi-Fi is getting OFF in GUI after this
Can anyone help me to resolve this
Susan
7,158件の閲覧回数
jimmychan
It is better to ask the wifi chip's company to provide you the proper wifi driver, firmware and nvram file. Mostly, they also have the Wifi Porting Guide for Android.
