Timer recourses used by MQX 4.1 (K70).
569 次查看
poul-erikhansen
I am using kinetics K70 and MQX version 4.1.
How can I find out with hardware timer devices is used by the system timer and scheduler in my system by the MQX system.
Poul-Erik.
标记 (2)
273 次查看
anthony_huereca
That is setup in C:\Freescale\Freescale_MQX_4_1\mqx\source\bsp\twrk70f120m\init_bsp.c starting on line 95.
It uses the ARM Cortex M4 systick timer by default, with a 5ms timer.
-Anthony
