I have a task that I need to run on two serial ports.
The same operations on both ports.
I tried using the Task Parameter from the Task Template but it didn't seem to work.
TASK_TEMPLATE_STRUCT MQX_template_list[] ={/* Task number, Entry point, Stack, Pri, String, Auto? */ {MAIN_TASK, Main_task, 3000, 9, "main", MQX_AUTO_START_TASK, 0, 50}, {TTYA, serial_app, 3000, 9, "TTYA", MQX_TIME_SLICE_TASK, 0, 50}, {TTYB, serial_app, 3000, 9, "TTYB", MQX_TIME_SLICE_TASK, 1, 50}, {0, 0, 0, 0, 0, 0, 0, 0}};
I have the task argument for TTYA set to 0 and TTYB set to 1
Each time serial_app starts the argument is 0
What am I missing?
tom
ps. I am using MQX 3.6
