TWR K60 HVAC web demo
1,742件の閲覧回数
UniversalTroope
I'm trying to run the HVAC webenabled demo on a TWR K60, using MQX 3.6.2 and IAR embedded workbench. The demo stops with "Waiting for ethernet cable plug in ...".
I have connected a cable, and the ethernet port LED's are lit. TWR-SER mode is RMII, 50MHz clock routed out, and TWR-K60 set to use that clock.
Any ideas?
タグ(1)
1,019件の閲覧回数
anthony_huereca
Try putting the board in MII mode. The MCF52259 BSP is expecting that, not RMII. It would be the original jumper locations on the TWR-SER, which you can find in the TWR-SER user manual: http://cache.freescale.com/files/microcontrollers/doc/user_guide/TWRSERUM.pdf
4 返答(返信)
1,019件の閲覧回数
UniversalTroope
It seems this doesn't work:
ipcfg_get_link_active(IPCFG_default_enet_device)
If I disable this check, the demo works fine. Any tips on how to get the cable check working?
1,019件の閲覧回数
PetrM
Senior Contributor I
Please make sure you have the switches on serial and processor boards set according to getting started manual.
It works for me.
PetrM
1,019件の閲覧回数
UniversalTroope
Sorry, it was the security demo that stops on that cable check, but the hvac demo also doesn't correctly detect the link state.
1,020件の閲覧回数
anthony_huereca
