Hi Folks,
In the main process of my application, inside one function, I call another function which uses the tty(b) driver to send out an ASCIIZ string. When this function is called, the app crashes (and causes a segmentation fault on my PC which is running CW when I'm debugging - which is strange).
However, if the error condition which causes the upchuck during the tty write does not occur, execution continues normally - in fact, the tty ASCIIZ function is called later in the program to give a status and there are no issues.
I suspect that I have a stack issue in the main process - is there any way to confirm that this is what's happening?
Does anybody have any ideas why CW has the crash as well?
Thanx,
myke
