Shell tasks blocks other tasks
1,132 次查看
simonepuschmann
I try to use examples with separate shell_task (like example in mqx - mfs - sdcard) and have the problem, that only the shell_task started.
The sdcard_task only started when I disable the shell_task. Must I something change in the config file to run the example correct?
标记 (2)
928 次查看
JerryFan
So the original example mfs-sdcard did not work? And which board you worked on, TWR board?
Or the example did not work after being modified? What modification you ever made?
929 次查看
JerryFan
