SCI: What IO_SERIAL_RAW_IO flag is?
1,048 次查看
oscar
I know that the question is very easy, but I didn't see the difference in the MQX code
862 次查看
PetrL
As written in MQX IO manual  - No processing of I/O done. But you are right, there is no need to set this flag (and no also effect on driver fuctionality), because this is default mode for serial driver.
PetrL
863 次查看
PetrL
PetrL
