Re: how to change network interface speed from 100mbps to 10mbps in FRDMK64
788 次查看
sudhakarp
Contributor V
Hi garabo,
          thank you very much. how to set auto_negotiate in KSDK .
i searched that but i got only 10 and 100 mbps selection only.
thanks and regards,
sudhakar p
1 回复
591 次查看
soledad
Hello sudhakar,
Please check the below thread and let me know if this helps!!
Anyone using K64F FRDM ethernet?
Sol
