Hi all,
I use K60 and MQX 4.1
I'd like to use socket receive TCP/IP packet every 100ms.
computer as server (device A)and k60 as client(device B).
Now K60 can receive data every 100ms .
My question is if device A disconnect and maybe 2mins later it reconnect, but the k60 can't receive data. I try to check the connection state if connection fail it will reconnect, but still not work.
socket_init();
uint16_t rlen=sizeof(raddr);
i=connect(sock_list[0],(struct sockaddr *)&raddr,rlen);
while(1)
k=RTCS_selectall(100);
if (i!= RTCS_OK)
shutdown(sock_list[0],FLAG_ABORT_CONNECTION);
socket_init();
recv(sock_list[0],buffer_tcp,30,0);
