I am using the "virtual_com" example app that comes with MQX 3.7. I'm running on a twrk60N512 with a Windows/XP PC .
When I run this example - receive "Unknown (USB) Device" , fsl_ucwxp.inf used.
This result take place also when, I try start hid_mouse_dev_twrk60n512 example.
When I worked with device from TI( tms320c5505) - usual driver from MS work properly.
Whether there is a possibility to help with this problem?
Nikolay
解決済! 解決策の投稿を見る。
Try to uninstall and install again driver that is determined by the INF file, if it helps.
