Hi Petr
I made a few tests with Processor Expert included in BSP. I think I found an issue related to Logical Device Driver BitIO_LDD and BitsIO_LDD. If I added one of these component, PE generates the files .s and .h for the build, but when you build the BSP library it does not create the object referred, and then produces error.
I think that there is a trouble in CW10.3 using MQX and Processor Expert. I attach Codewarrior screenshot to best understand.
Reagrds
Abele
Sent: Friday, April 26, 2013 1:50 PM
To: abele barbieri
Subject: Re: MQX Software Solutions - Porting project to MQX
created by petr.uhlir in MQX Software Solutions - View the full discussion
