PageOrderMap::init Change to uint16_t entries
ソリューションへジャンプ
2,492件の閲覧回数
randalljordan
Has anyone been able to update PageOrderMap::init  to uint16_t entries?  I needed to change the entryCount to 1025 to support the NAND flash our board uses.  The comment states that if the assertion hits that you need to change to uint16 entries, but I can't seem to find any documentation on what needs to be changes to allow for uint16 entries.
Any help is appreciated.
Thank you for your time.
Randy
2,336件の閲覧回数
randalljordan
jonalvik Nice Work
Big thank you to Jon Alvik for supplying the information I was missing, that was needed for uint16_t entries.
For those who stumble upon this page, I've attached what needed to be changed.
2,337件の閲覧回数
randalljordan
jonalvik Nice Work
