PWM driver for Kinetics K70 on MQX 4.0??
RuiFaria
Hi everyone,
I am using kinetics K70 on MQX 4.0 and i will need to use one output as PWM.
where can i find PWM driver implementation?
Someone can help me?
Thanks in advance,
Rui Faria
LuisCasado
HI Rui,
There is not PWM driver in MQX. You can write your own driver (AN3902) or use Processor Expert in your BSP, the easy way.
Luis
RuiFaria
Hi Luis,
Last time i found PWM driver but for M5225X MCUs, i was hoping to find something similar for K70.
I will try to implement my own driver.
Thank you for your attention,
Rui
