Thanks for sharing the document.
I’m planning to integrate RTCS stack into my GT202 Wi-Fi driver and application using KSDK-1.2 MQX framework.
Can you provide a sample example application to me which will use the RTCS stack with KSDK-1.2 MQX?
It would be great if you can provide me a RTCS porting document using KSDK-1.2 MQX.
Suresh
