That threat I think, it is using PE to configure KSDK drivers. Derek Snell , can you please confirm?
Unfortunately, the MQX 4.1.1 doesn't have bsp projects with PE enabled for the KDS.
But in the case of MQX for KSDK, you can use PE to configure the KSDK drivers and perhaps use the non KSDK components (LDD) at the same time. I have never tried that. You could try.
