MQX with Codewarrior on Kinetis Micro
2,177 次查看
Briwal
Codewarrior 10.1 BETA added kinetis microcontroller support.
Is MQX supported with this version of Codewarrior?
From what I can see, Kinetis MQX (version 3.6.2) is supported only in IAR.  Has anyone seen otherwise?
标记 (3)
919 次查看
DavidS
Hi Briwal,
You are correct.  CW10.1 BETA has baremetal support for Kinetis.  The FSLMQX3.6.2 only supports IAR tools today.  Next release of FSLMQX in April-ish time frame should have CW10.1 support.
David
920 次查看
DavidS
Hi Briwal,
David
