I am working with Freescale MQX and I try to implement CLU load measurement. I have got big problem because one of my task (standard MQX shell task) consume all CPU (program never goes to idle task).
Do You know how to change it ? Maybe Shell task could work in interrupts ?
I am working with 3.7 version of MQX.
I would be very grateful for any help.
Please use interrupt version of serial interface e.g. ittya instead of ttya:
In user_config.h file:
#define BSPCFG_ENABLE_TTYA 0
#define BSPCFG_ENABLE_ITTYA 1
#define BSP_DEFAULT_IO_CHANNEL "ittya:"
I hope it helps you.
RadekS
