Dear Sir/Madam,
Is MQX available for Vybrid processors?. If not when it will be available?
Is there ISO 7816 support for MQX?
Best regards.
Mehmet Ali Ipin
Hello Mehmet Ali Ipin,
VYBRID processors are going to be supported in next MQX release which should be released in Q2 2013.
MartinK
Dear Martin,
Thank you for your answer,
Is it for only Cortex M4 or, Cortex A5-specially VF3XX also supported?
Thanks and best regards.
VF6XX will be supported in the MQX.
So does that means MQX will support VF5XX that has a Cortex-A5 only?
To be more specific, the MQX is supported Cortex-M4 already, and Cortex-A5 will be supported in this year release.
