MQX_USE_IO_OLD
MQX_USE_IO_OLD
1,932 次查看
arnogir
Senior Contributor II
I'm facing some problem on the MFS.
I now update to the MQX 4.2.0.2 to hope to resolve these problem.
During this phase, I seen a parameters : MQX_USE_IO_OLD which is set to 1 into My config.h.
Is anybody can say to me what is exactly the impact of this option?
1,844 次查看
soledad
MQX_USE_IO_OLD  set to 1 use the old MQX IO callbacks.
I hope this helps, have a nice day!
Soledad
1,844 次查看
arnogir
I see that,
So what is the difference?
I seen inot the mfs for exemple, this use fseek instead another call.
What is the difference in point of view of the user?
1,844 次查看
soledad
The following document mentions the changes between MQX version,
https://www.nxp.com/docs/en/user-guide/MQXCHLGUG.pdf
please let me know if this helps,
Have a nice day!
Soledad
