MQX Parity Problem in UART for MCF51xx
ソリューションへジャンプ
1,455件の閲覧回数
miltongdavid
I tried the follwoing code in the init
Original
 /* 8-bit mode. Normal operation */
   sci_ptr->SCIC1 = 0;
Changed
   sci_ptr->SCIC1 = 0x03;
Then i recompiled and ran the program. But iam getting error
801件の閲覧回数
miltongdavid
I forgot to set the data length to 9 bits. Parity bit is added as the 9th bit.
802件の閲覧回数
miltongdavid
