Back when MQX 3.8 was released, support for 64-bit numbers (llu and lld) was added for printf and scanf. Can we get a patch to support 64-bit for sscanf?
Hello Aaron,
MQX supports printf and scanf for 64-bit numbers and %L modifier.
If you have some problem please try increasing the stack size of the task.
I hope this helps, have a great day,
Sol
Sol,
You apparently didn't read what was written. It is understood that printf and scanf have support for 64-bit values and was mentioned in the very shorty original post. What was asked and is requested is that sscanf have supported added for 64-bit values as a patch. I know it's unsupported for sscanf and can be easily traced in the MQX code to determine such. Suggesting to increase the size a task stack is useless.
-Aaron
