MQX 4.2 USB v2 on K70 MCU
2,096件の閲覧回数
josephchen
Has anyone ported the new USB v2 stack to K70 MCU? I've ported the host stack and tested with MSD, but the filesystem doesn't work normally.
ラベル(2)
タグ(4)
1,778件の閲覧回数
soledad
Hello Joseph,
Attached you can find a document that shows how to port the USB unified Stack to a new platform. The example uses a K70 device.
Sol
1,778件の閲覧回数
josephchen
This is what exactly I have done, and it doesn't work well. Therefore, I would like to know that if any has ever run the new USB stack on K70 successfully.
