MQX 4.2 IMX6SX BSP Missing?
1,075 次查看
w2vy
Contributor V
macl
As shown on the page announcing the 4.2 release, there was a 4.1 patch that provided support for the i.MX6 SoloX M4 core.
I downloaded the 4.2 release and did not see the SoloX BSP.
Was that an oversight?
Tom
829 次查看
macl
Senior Contributor I
No oversight.  The I.MX 6 SoloX BSP is provided in the separate MQX 4.1-based standalone release.  Architecturally it is a bit different and was better kept in its own branch.  To my knowledge, the updates in MQX 4.2 aren't applicable for the SoloX BSP since it does not include TCP/IP or file system.   Hope this helps.
Mac
830 次查看
macl
Mac
829 次查看
w2vy
Contributor V
Ok thanks, that makes sense. from the naming I thought the release was a PATCH to 4.1, but upon looking closer it is a stand alone release
thanks!
See you at FTF!
829 次查看
johannesstuttne
Hi, is their any TCP/IP support planed in the mqx version for the imx6SX?
