MQX 3.8.1 twrk60n512 intflash.lcf file has .bss and .data both in .main_application_data
841件の閲覧回数
David_Wu
if you look at the file - MQX 3.8.1 twrk60n512 intflash.lcf file, it  has .bss and .data both in .main_application_data - is this by mistake or on purpose - at least this is not consistant with other targets - and seems wrong. this makes the image unexpected larger because it includes uninitilized data and is useless(at least to me).
622件の閲覧回数
BielikM
Hi David,
You are right about this linker command file. Now is create new section for bss in the same way as in other platform. Thank you for your repor. This fix will be available in MQX 4.0.0 release.
Bielik Martin
622件の閲覧回数
c0170
Senior Contributor III
Hello david_wu,
I am going to find out why they are put into main_application_data.
I will let you know the outcome.
MartinK
