MFS, how get the handle of a file?
1,462件の閲覧回数
emanueletrapani
i work on a k64f, MQX 4.2.
There is a way to recover the handle of a opened file if i miss the fopen() return handle?
I have the pathname and the filename.
thank you
Emanuele Trapani
タグ(1)
1,297件の閲覧回数
danielchen
Hi Emanuele:
File handle is a memory allocated for the given FILE_PTR from system memory pool.  Theoretically, it is possible to get it by walking through kernel data. Unfortunately MFS does not provide this API to do that.   You can save the fopen returned file handle into a global variable. I don't think it will be missed .:)
