MFS_SHARING_VIOLATION when opening in "a " mode after open in "r" mode
Fabi
When I open a file with "r" option, then closing it and opening it again with "a+" mode,
MQX runs in MFS_SHARING_VIOLATION in mfs_open.c:
            // If we are opening to write, the file can't already be opened.
            if ((access == MFS_ACCESS_WRITE_ONLY) || (access == MFS_ACCESS_READ_WRITE)) {
                error_code = MFS_SHARING_VIOLATION;
What's wrong (with my calls)? Any ideas?
Tags (2)
Fabi
It was an application issue. In some circumstances, where was no "closing" between the two "openings".
diego_augustus
Hi F.Bilz
Did you solve this problem?
Thanks.
Fabi
