Solved! Go to Solution.
Where can one get this "MQX BSP for the K60 120Mhz 1MB Kinetis chip" that Tim speaks of? Not in MQX 3.8 yet. Specifically, support for the MK60FX512VMD12 in a BSP that we can clone/adapt, even better with PE support.
To your question TIm, see
Document Number: PEXDRVSGETSTARTEDUG rev1
page 6
section 2.2
Adding Processor Expert Project to Existing Project
for the procedure.
That is where I started the process you described, then discovered that ProcessorExpert does not support that processor yet, at least not in the version to which I have access. If there is an early realease I would love to test it.
Thanks.
page 6
section 2.2
for the procedure.
Thanks.
