First of all, reading value of any synchronization object (e.g. lwevent) is not task-safe and handling with those objects should be done only through blocking / setting functions.
To fulfill your request, I reply that if you want to read value of lwevent, use:
LWEVENT_STRUCT some_event;
/* some initialization code here, out of scope */
_mqx_uint lwe_val = some_event.VALUE;
Message Edited by JuroV on 2009-10-05 10:17 AM
