Is it possible to change the MQX 4.0 root directory?
已解决
跳至解决方案
1,183 次查看
cavebiker
Contributor V
Is it possible to change the MQX 4.0 root directory or install it to a different place?
This is a configuration management thing, no biggie if it can’t be done. MQX Rocks---
Cheers,
Tom
1 解答
1,050 次查看
cavebiker
Contributor V
Thanks Kojto,
I needed to do an uninstall and install, that did it :smileycool:
Cheers
在原帖中查看解决方案
2 回复数
1,050 次查看
c0170
Senior Contributor III
Hello Tom Junkans,
yes, it allows you to install it to specific directory.
MartinK
1,051 次查看
cavebiker
Contributor V
Thanks Kojto,
Cheers
