Is bind() mandatory for a stream TCP connection?
954 次查看
lucky06200
I send a TCP frame with :
  1. socket()
  2. connect()
  3. send()
  4. shutdown()
Is this path OK, or is it needed to add a bind() between socket and connect ?
Thank you for attention.
标记 (5)
818 次查看
susansu
Yes you need add a bind() before connect to assign the port number, address and protocol  the socket use , so that the socket could receive the other end's reply.
819 次查看
susansu
