If ittya used as the default IO channel instead of ttya, the Shell cannot print anything? Any hint?
664 次查看
yabazaki
If ittya used as the default IO channel instead of ttya, the Shell cannot print anything? Any hint? Using MQX4.0.2. Anybody who had ever met this? And any cause? Does the Shell suppor the ittya or not?
标记 (2)
0 回复数
