IM8QM core-image-minimal building for imx-gpu-sdk
已解决
跳至解决方案
5,396 次查看
rahulM
I am new to NXP SOC and Yocto. I build code for core-image-minimal and i need to add graphics sdk from source meta-freescale-distro/recipes-graphics/imx_gpu_sdk
I made following changes in build_wayland/conf/local.conf
added IMAGE_INSTALL_append = " imx_gpu_sdk"
bitbake imx-gpu-sdk
I got following errors please find attachment
Please let me know how to solve this issue.
Thanks and Regards
Subramanya N M
1 解答
5,360 次查看
joanxie
ok, depends on what bsp version you use, just refer to the yocto user guide , the command I sent to you is for old bsp
在原帖中查看解决方案
11 回复数
5,380 次查看
rahulM
yes build for wayland...let me know procedure how to include imx-gpu-sdk in core-image-minimal
5,378 次查看
joanxie
core-image-minimal is A small image that only allows a device to boot. so if you need to enable gpu sdk, you must install the wayland images
5,375 次查看
rahulM
yes i agree.. The procedure for building sdk i don't know...please let me know procedure...
标记 (1)
5,373 次查看
joanxie
try to use the command like:
# DISTRO=fsl-imx-wayland MACHINE=imx8qmmek source fsl-setup-release.sh -b build-wayland
# bitbake imx-gpu-sdk
then you should find imx-gpu-sdk under /opt
5,371 次查看
rahulM
Thanks...ok sure i will see
5,370 次查看
rahulM
Error:
bash: fsl-setup-release.sh: No such file or directory
5,368 次查看
rahulM
changed to
DISTRO=fsl-imx-wayland MACHINE=imx8qmmek source imx-setup-release.sh -b build-wayland
5,361 次查看
joanxie
5,350 次查看
rahulM
now i want to add qt5-module similar steps shall i need to follow
5,347 次查看
joanxie
for new questions, pls recreate a new case for it, thanks
5,385 次查看
joanxie
try to build wayland or xwanland as backend
