How to use timer interrupt or timer isr?
1,496 次查看
Abil
hello,
i am using FRDM k64f with codewarrior 10.6 and MQX4.2 RTOS, i want to use timer isr or timer interrupt to make my task periodic...(ie. i want to make timer based interrupt which will call my task periodically) can anyone help? Is there any example code that can help me ....
Thank u.
1,157 次查看
danielchen
I suggest you check the timer example in the MQX installation path.
C:\Freescale\Freescale_MQX_4_2\mqx\examples\timer
This example creates two timers, withe 2 seconds period, the terminal print "ON" & "OFF" three times in turn.
1,157 次查看
Abil
Thank u daniel.. I want to configure periodic timer interrupt (hardware interrupt) and based on that want to call my task...could u suggest how to do this?
Sent from Samsung Mobile
