Hi All,
When I use
lwgpio_int_init(&switch4, LWGPIO_INT_MODE_RISING);
to set the interrupt mode for a I/O, how can I set the interrupt mode to both edge?
Thank you.
-Daniel
Solved! Go to Solution.
On MQXIOUG.pdf page 244, it said you can set it as
lwgpio_int_init(&switch4, LWGPIO_INT_MODE_RISING|LWGPIO_INT_MODE_FALLING);
