How to export a MQX specified to a target board?
danielchai
Senior Contributor I
Hi All.
I ported the MQX for my target board. Now I want to move to another PC, how can I export the MQX for my board and add it to another PC which already installed MQX?
I use the BSP Cloning Wizard export the MQX tree, then what should I do next?
Thank you.
-Daniel
soledad
Hello Daniel,
You can copy the entire MQX folder from you first installation (your old PC) and paste the folder to the new PC (after you install MQX), for this option you don’t need to use the cloning wizard.
I hope this helps!!!
