How to close a Wi-Fi connection using a K60 with the Rs2101
915件の閲覧回数
slaroche
   I am working on a wifi application that requires to successively connect to different WiFi access point.  I can connect to an available network, but I haven't found how to disconnect from that network on request.
  Is there a way to do this ?
タグ(1)
753件の閲覧回数
slaroche
... Turns out that I didn't find any clean way to do this.  So I am resetting the module using power and reset lines from IO control.  A function named "rsi_power_off_power_on()" is already present but not used.  I used it, added a few function to recall device initialization and it did the trick.  Who ever have a better way, please let me know.
