Does anyone have an example of memory-to-memory DMA data transfer with MQX v4.X.X?
已解决
跳至解决方案
3,315 次查看
m4l490n
Contributor V
I need to do a 1024 byte transfer from one RAM buffer to another and I thought that this is the perfect candidate for a DMA operation, nevertheless, I don't know how to do this under MQX and I can't find examples for that so I'm wondering if anyone has done this that can share an example.
标记 (2)
1 解答
3,250 次查看
danielchen
I looked for an example and I didn't find exactly what you need but attached one article:
Using the DMA module in Kinetis devices.
Hope it helps.
在原帖中查看解决方案
1 回复
3,251 次查看
danielchen
Hope it helps.
