DNS address changed every time after dns domain to IP
1,263件の閲覧回数
errsionjack
I was using MK60D100M board,DNS address changed every time after dns domain to IP and it works ok.But ithe dns addrss isn't reasonable.The result was in the attachment,and my PC's DNSdoesn't changed every time.I don't know this why.and my customer often complains it.
1,117件の閲覧回数
RadekS
Currently it is not known issue.
Could you please specify your version of MQX? Did you made any modification in RTCS code?
From my point of view it looks like problem with DHCP or rather problem with memory pointers where your code rewrites your settings.
Could you please use wireshark for recording presented network traffic and place it here for analysis?
Also files with your project could be helpful for reproducing it on our side.
RadekS
