While there are general non-blocking support in RTCS, I cannot find any information, also connect() has this support.
I'm looking into having a go at RTCS for my project, and are trying to find the disadvantages for doing this..
Can anyone enlighten me?
Thank,
Micael
已解决! 转到解答。
In the connect() section of the RTCS User's Guide, it states:
"This task blocks, until the connection is accepted, or until the connection-timeout socket option expires."
The manual can be found in the docs directory in your MQX installation, or on the web here
Hopefully that answers your question
Hi Phil,
Thanks! But actually, I think the zip you linked to, are for Freescales Interniche-Lite package, which is different from the MQX, as far as I understand.
I had a look at that before, but it seamed too limited for me, and I was not sure about ongoing support/update with it. I hope, with MQX, that Freescale has a more robust plan, and also longer term committment with MQX, otherwise, many of us better turn to other solutions (open source or commercial).
Micael
